1963 Evinrude Big Twin impeller
tich
Hi Chaps<br />Need Help!<br />How easy is it to change the cooling water impeller on my 63 Big Twin outboard? I would be gratefull for instructions if possible. Another quick one, what spark plugs?<br />Regards to you all<br />Tich
CATransplant
Re: 1963 Evinrude Big Twin impeller
The impeller change isn't too difficult a job, really, but you really should have a manual on hand for reference. You'll find it will save you tons of worry, and that's more than worth the cost.<br /><br />What model motor do you have? And does it have the electric shifting mechanism or the older-style mechanical shift mechanism?<br /><br />The answers to those questions make a difference in the process.
CATransplant
Oh, yes, plugs. The correct plug for that motor is the Champion J4C. Under slow trolling operation for long periods, the hotter J6C is preferred. Like most here, I recommend sticking to the Champion brand.
tich
Its has a mechanical shift. I have got a sort of manual but it doesnt give any details of what to do with regard to changing the impeller. Your help would be very much appreciated. Thanks for the info on the spark plugs.<br />Regards<br />tich
Paul Moir
Here's the quick version:<br />0) Remove the pile of screws that hold the midsection cover halves together. This is to get access to a bolt that holds the lower unit on.<br />1) Disconnect the shift linkage behind the window on the side of the midsection. Completely remove one of the two bolts.<br />2) Remove the 6 small bolts and 1 large bolt that holds the lower unit on.<br />3) Pull off the lower unit.<br />4) Remove the three screws holding the water pump housing on. Lift the water pump right up off the driveshaft. Careful not to lift up on the driveshaft or loose the impeller key if it comes loose.<br />5) Remove the impeller off the driveshaft. The driveshaft may need some cleaning.<br />6) Install a new impeller. It's not worth even thinking about the old one at this stage.<br />7) Coat all the threads of all your screws and bolts with sealer. This will make them easier to remove next time.<br />8) Install housing over impeller while turning the driveshaft clockwise so the vanes fit the housing. Screw it down<br />9) Regrease the splines at the end of the driveshaft.<br />10) Reinstall the lower unit lining up the driveshaft, the shift rod and coupler, and the water pump tube.<br />11) Make sure the shift rod connector is fully installed, and install the bolt you removed earlier from the coupler. Don't strip out the soft brass coupler.<br />12) Replace the window.<br />13) Reinstall the back half of the midsection cover and test.<br />Hope this helps!
CATransplant
OK. Here's the basic drill. It would help if you had the manual, though, and I make no guarantees that I didn't miss something. Give yourself a couple of hours for this job, the first time you do it, and work slowly and methodically. Have a good place to put parts and keep parts from different assemblies separate:<br /><br />1. I'm not certain if this model has the outer cover on the back of the midsection. If it does, remove the phillips head screws and remove the cover.<br /><br />2. Shift the outboard into Forward gear. Turn the prop clockwise, if necessary, to shift. On the starboard (right) side of the midsection, you'll find a small cover with two screws. Remove the screws and the cover. On most of these, another cover is inside. If so, remove the TOP screw only, then loosen the bottom one and let the cover swing down. NOTE: Be careful here. You don't want to drop the screw down the exhaust tube. What I do is use a socket and keep it up against the cover as I unscrew. When it's out, I carefully put a finger under the socket and make sure the screw comes out and doesn't drop.<br /><br />Inside this cover you'll see a brass clamp fitting, rectangular in cross-section. A small bolt goes through it at the top. CAREFULLY...remove that bolt, using the technique described above. The upper shift rod is held by this clamp.<br /><br />2. Tilt the motor up, as if for trailering, using the screw-in bolt or pin to hold it in position. Remove the bolts/screws which hold the lower unit onto the midsection, including the one revealed by removing the cover, if one exists. If they don't want to come out, tap the bolt heads lightly with a hammer to break up the corrosion. Do not force these. Twist one off and you'll complicate the job.<br /><br />3. Carefully remove the lower unit from the midsection. You may have to bump it lightly with a rubber hammer or other soft tool to free it. It will come off, complete with the driveshaft, lower shift rod and clamp.In most case the water tube(s) will remain in the midsection. If they come out, reassembly will be a bit more difficult, but still doable. Remove the o-ring from the top of the driveshaft. You will want to replace this on re-assembly. DO NOT REMOVE THE DRIVESHAFT FROM THE LOWER UNIT!<br /><br />4. Locate the impeller housing on the lower unit. The driveshaft extends through it. Remove the screws holding the cover in place, then slide the cover up and off the driveshaft. Remove the rubber impeller, noting the direction the arms bend. A small woodruff key is there to drive the impeller. Do not lose this!<br /><br />5. Place the new impeller over the drive shaft and slide it down, positioning the woodruff key, then sliding the impeller over it, matching the groove in the impeller with the key. Take your time.<br /><br />6. Give the inside of the impeller housing a thin coat of undiluted liquid dishwashing detergent, then slide the impeller cover over the drive shaft and down to the impeller. Carefully bend the arms of the impeller in the same direction as the old one and work the cover over the impeller slowly and gently. This is the trickiest bit of the whole thing. (Note: if you can't remember the direction, turn the prop clockwise (looking from back of the motor)). It also helps to turn the prop as you work the cover down over the impeller. Once it's seated, reinstall the screws. If you forgot to shift into Forward at the beginning, you can do that now by pulling up on the shift rod.<br /><br />7. Look at the top of the water pump. You will see one or two rubber grommets. The water tube(s) fit into these. If they are damaged, replace them. Otherwise, smear some liquid dish soap on and in them to lubricate them for easier insertion.<br /><br />8. Place a new o-ring in the groove at the top of the driveshaft, at the base of the splines. Use some marine grease to lightly grease the splines.<br /><br />9. Slowly and gently...slide the driveshaft and shift rod back into the engine as you replace the lower unit. As the lower unit gets close to the midsection, align the water tube(s) with the grommets in the water pump. Most engines have these tubes cut at an angle to assist you in getting them in place. If necessary, turn the prop clockwise just a little to get the driveshaft splines aligned. You may well have to wiggle things around to get all the parts in alignment. When the lower unit is fully flush with the midsection, re-install the bolts that hold it to the midsection.<br /><br />(NOTE: if the water tubes have come out with the lower unit, remove them from the water pump and fit them into the upper unit. It ain't easy, but you can do it if necessary. This doesn't usually happen, though)<br /><br />10. On the midsection, make sure that the upper shift rod is in place in the brass clamp. You can manipulate the shift lever and move the clamp down into neutral, if necessary. Note the groove around the shift rod. That groove MUST align with the bolt hole in the clamp. Re-insert the clamping screw, with star washer. (Here, I put some grease in the socket I use to help hold the screw. If necessary, put a nut in the socket to have the screw protruding from the socket, far enought to engage the threads. Don't drop it down the exhaust tube, please. Tighten the screw firmly, but don't overtighten...you can strip the threads fairly easily.<br /><br />11. Replace the inner cover, again being careful not to drop the screw inside the exhaust housing. Don't forget to tighten the lower screw on this cover. Replace the outer cover, if any.<br /><br />12. Replace the external midsection cover, if it exists on your model, and you're done. When replacing this cover, make sure the hose with the little bellows for the idle relief fits into the hole in the cover.<br /><br />13. With the lower unit submerged in water, well over the water intakes, start the engine (in neutral) and check for some water coming out the idle relief hole.<br /><br />That's it. Take your time and pay attention to where things are. Don't forget the new o-ring on the driveshaft and the grease. Don't lose any parts. The first time's a little scary, but it gets easier after that.<br /><br />If I forgot something, I apologize. Pay attention as you work.
Paul Moir
Holy moley! I think CATransplant has you well covered there! :D
tich
I cannot thank you enough Sir. I shall endevour to tackle the said task when I get time over the next few days. Thanks again.<br />Tich
CATransplant
Paul....you old sea dog! You posted your quick step version as I was writing the long one. I hadn't seen your face for a couple of days, so I decided to take on the job. Your version was much more concise than mine....<br /><br />I did forget to warn our mutual correspondent about the foam that will emerge after using dishwashing soap to lubricate the impeller housing, though. You should have seen my barrel when I fired her up! I still like using the soap, though...it slicks things up very nicely and makes assembly a lot easier.
tich
Hello again.<br />If I may ask another quick question regarding the impeller housing. I have removed the impeller as you suggested (Thanks yet again) and have found that the impeller housing is quite pitted. I wouldnt say that it is badly pitted but I wondered if this could make a noticable difference to the operation of the pump and would slight pitting justify replacing the housing. Not sure if Im being a little too picky but thought it wouldnt hurt to ask.<br />Regards<br />Tich
CATransplant
It's not great that the housing is pitted, but it's not a disaster, either. If you can find a new one (a tough task, I'm afraid) it would be good to replace it, but if it's only slightly pitted, just go ahead and use it. It might affect the life of the new impeller a bit, and you might want to begin a search for a new one, but it'll work.<br /><br />Mine was a bit pitted, as well, but I could not locate a new housing. I'm still looking, and will replace it if I can find one. I'm not willing to lose the use of the motor, though. It's pumping fine.
tich
Thanks. Ill give it a good clean and live with it. Maybe one day Ill be lucky and find a new one. <br />Tich.
