1963 evinrude 75 horse electric shift
Jeffrey M Goldberg
The charging system quit.When I measure the voltage on the battery at three quaters throttle. All I get is battery voltage around 12.25 volts when battery is fully charged.I used to get around 13.75 volts at that rpm and it goes down from there as I use the boat for three or four outings.11.00 volts or so. The amp meter on the boat used to read in the charge side of the meter.around ten amps and now goes slightly to the discharge side when useing any aserories.When no asseories are being used the meter reads zero.I need to know how to check the charging system starting from the stator to the battery.I have a manual for that year and make but the book covers many years and make and is kind of confusing. Any help would be great let me know if i can give you more info to help with any replies.Other than that this old motor runs great I love the motor. Look forward to hearing from you.
OBJ
Re: 1963 evinrude 75 horse electric shift
Jeff....look in your manual for a section that deals with checking the rectifier. This is the thing on the starboard side that has a triangular base and what looks like a tin can setting on it. There will probably be three wires coming from it, a red, and two yellows. One of the yellows may have a grey stripe on it. Don't know for sure, don't have my book here in front of me.<br /><br />The rectifire takes the AC voltage from the stator and turns it to DC for battery charging.<br /><br />It's a place to start.
juice71
interesting, I have the exact same motor and year.
Jeffrey M Goldberg
So am I correct in asuming that this motor is 20 AMP regulated charging system?
