1963 Evinrude 40 hp Gasket Questions
twostroke
I am trying to find a gasket for a 1963, 40 hp, model number 40373d Evinrude. The gasket is between the gear case assembly upper unit and the exhaust housing. As i took the two apart, there is a gasket. I looked on several web sites and none of them indicate that a gasket exists. If this gasket is obsolete, what type of liquid or spaghetti gasket should i use? Reading through the service manual all that is says to use on the o rings/rubber seals is a liquid sealant...what type should i use?
F_R
Honorary Supreme Mariner
No gasket is used there, nor needed there. Anything that leaks out there was heading for the underwater exhaust anyway. Just slap it together and don't worry about it. The V-4 models did use a gasket for a short while, but that too was discontinued.
