Dexter1972
- Sep 11, 2024
- 7
So I bought a 1963 28hp cheap. Looked pretty clean but had no spark. Did the coils, condensers and points, and even with no carb rebuild, which is coming, I got it running fairly well. Problem is it is stuck firmly in neutral. I've tried moving the prop, tried shifting it with motor running and moving the throttle down but still won't budge. I then removed the lower unit thinking it was something wrong there. The lower unit shift rod is moving correctly off the motor. And the shifter still wouldn't budge with no lower unit on it. At this point I'm lost as In a relative newbie especially on anything this old. When I wiggle the shifter with the lower unit off, I can hear the shift rod wiggle as well, like it wants to move. Any help would be greatly appreciated and probably save me from pulling out the last few hairs I have.
