valvebounce
- Mar 18, 2014
- 102
I bought this engine used,I have brought it back to good running order.
On a test run my 14ft fibregass boat would not get on the plane,the boat has remotes and steering and two seats,and isn't a heavy boat.
I think the prop is the wrong pitch.I can't find any Id numbers on the prop.
I suspect the prop that is on at present was for a heavier boat.
Anybody know what the standard prop part numbers are?
The prop is at the right height on the transom,and the wake is huge,but the boat won't plane.
I intend using the boat for close inshore fishing,but with the hull not getting on the plane I am only getting 8mph at best.Probably because the hull is in dispacement mode.
Any help will be much appreciated.
