63evinrude10hp
Thread starter- Joined
- Jul 10, 2011
- 9
ok guys, i need some help, i know mechanics very well, iam very skilled in auto, boats uhhhh little bit, know the basics of internal combustion. i have a 63 10hp sportwin, i need alot of suggestions, the guy before me put all new electric in it IE coil, points etc.. now my problem, it seems like when its off water, hooked up to hose for water, it runs pretty good, if i play with mixture screws but a little tempermental, now i put in water, under a load, and it runs ok but at full throttle it seems like half throttle, out of water it idles just fine, in water it dies, i have to start it in gear at half throttle, i just need some suggestions on what to do, its winter here, and want to do it right this time, so i dont miss so much fishing timr, by using my 30lb thrust electric motor on my 12 ft v hull alum boat!!! i seen it run top throttle once, for like 10 seconds, it was fast!!!!! but i dunno i stumped, it runs great out of water, in water it seems to be under a load not as much power, has good compression, new plugs old wires????????? new coil, points condensers, the wires for plugs are old though. ant suggestions?
