1963 evinrude 10302E 10hp crankcase sealing
BrianWright1963
I Have worked on This motor From Crankcase To Carburetor, I have to ask a question ,On the crank bearings The bottom Bearing, #2 There is a O Ring That goes around the outside of the bearing, and into a groove , that helps stop the crankcase from loosing pressure / or pulling air, on #2 intake Why is there not a O Ring on Crank Bearing To seal #1 The intake as well?? Does any one Know Thanks
F_R
Honorary Supreme Mariner
Look closely and you will see a small hole in the upper groove, leading down to the intake manifold. Vacuum in the manifold pulls air and a bit of fuel down to the manifold. This does two things: It prevents leakage to the outside world, and it creates a suction that draws fuel/oil up into the roller bearing for lubrication.
BrianWright1963
Yes i seen it. It looks like it splits and goes two directions or pulls from one direction and crosses and goes into the intake area. This is only on one side of the crankshaft is that right , That is what i am seeing,and th other side just has a rubber o ring with the locating pin And one in the center that has a hole on both sides for crank pressure oiling for the center bearing, the crank bearings are turned around, to me, having the thrust side out against the seal instead against the crankshaft I would assume that it is so they can receive oil as well, had me a bit confused for a minute i thought that they received the oil from the locating pin area Thaat is what finally told me, that the trust side goes against the Seal leaving a small gap between the bearing and the crank 3/16 inch than the springs and the keeper !!! Thrust side of the crankshaft against, or along side the center bearing, as well, to center the crankshaft as well.... trying to understand why everything is how it is in the crankcase area oiling pressure and fuel.,. do you or any one have the original compression of this motor I am at about 95 or 100 psi on both cylinders is this good, Bad. Fair,.. Do you know Because it ran good at 90 lbs per cylinder but i do not know if this is a high or low compression motor
in relation topiston to deck clearance and ccs of the head and the stoke etc,.. The only had this one 10hp for a few years and i dont know if they can be milled or not for compression reasons?? I checked and there is a little bit i can take off of the block and the head if i have to and the piston still clears @ jTDC Can i get ;your oopinion on this..
Thanks
F_R
The flat surface on the bearings is a sealing surface, not a thrust surface. The carbon seal rides against it and prevents escape of air/fuel. Yes, I believe the crank is located by the center bearing. 95-100 is good. OMC never did post specs on that. Start modifying it and you are on your own, as far as I am concerned. A minimum of material to straighten the gasket surfaces is acceptable.
BrianWright1963
I have one more question I can not seem to find a definitive answer on,. the torque for the head bolts is 120 to 150 inch lbs ok, or 120 to 130 inch lbs
F_R
My Evinrude factory service manual (two of them) says 96-120 inch pounds.. Retorque after test run and cool-down.
BrianWright1963
I need to reset the needle high and low adjustments, I rebuilt the carburetor and counted the turns in and out for the initial adjustment, and took the carburetor out again for motor rebuild and failed to count the turns out from the seating postion is it 1 1/2 to start with or ??? Last question I ask was Head Torque the 96 to 120 and retorque after running the engine at an operating temperature is what I had gotten but it seemed low, I will go with the 96 to 120 and the retorque ,. very easy to over torque so I have to be careful I do have a inch pounds torque wrench it comes out to be about 10 to 12 ft lbs I will go with the inch pnds more accurate I have the beam type and the hydraulic type the beam type is the inch pnds I will go with the beam type I have
