FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have a 1963 75hp it will run for ten seconds or so then dies it will fire right back up. i just got the boat it hadn't been started for 4 years before i got it
is the timming mark on the dist.pulley supposed to line up with kill switch or the line on top of the mounting bracket? i have a manual ordered should arrive next couple days.
It is used for setting the timing with regards to the flywheel. Marks on dist pulley line up with mark on bracket and dot on flywheel is aligned with mark on block or flywheel/ring gear cover.
I have the same motor. I've found it needs points, condensor, plugs, fuel filter at least anually. Also a good dose of carb / choke cleaner to free up the choke. If you haven't done these yet - start there.
