yorab
Ensign
Thread starter- Joined
- Jul 6, 2002
- 960
First of all, great to be back reading some interesting posts here again.
Quick summary: I finished my engine rebuild back in 2011 and immediately moved out of the country. Nearly every component was replaced during my rebuild.
The boat and engine has been stored since then. I'm back temporarily and I'd like to get some hours on this engine. I have probably 10 hours on it total.
I now have a weird cooling issue that I just can't figure out. I have a pretty good understanding of the cooling system, but I'm stumped.
Current problem: I have a hot condition on the port cylinders, especially the top. It's running around 210 degrees on that top cylinder. The thermostat never seems to open because I'm not getting any spittle out of the upper exhaust port. I realize that there never is a full stream from there, but I've seen this thing working properly in the past spit some water when the thermostat opens. Now, no spittle at all. I just replaced the old impeller (ha! it only had 10 hours on it), because I wanted to rule out brittle vanes (the impeller was nice and supple but I replaced it anyway).
I tested the vernatherm and it opens around 145 degrees (designed for 143). The vernatherm is NOS. I have another vernatherm with about 20 hours on it and its behavior is identical. The pistons on each push out about 1/8 of an inch or so. I went to the marina today and they allowed me to test a vernatherm that they had in stock. Its behavior was identical to both of mine. So, 3 different vernatherms acting the same. I must assume that they work properly.
I'm definitely getting water flow because I disconnected the hose at the hot water choke and I have a solid stream from there.
Just to rule out some things, I then took the thermostat guts out and idled her at the dock. The heads were of course cool (~110 degrees) and there was a good spittle coming out of the upper exhaust port.
I can't figure out why this thing is hot with the thermostat components installed. I have more info, but I don't want to write a book on this post. If you have advice, I can let you know if I've tried it yet or not, and what came of it. Any ideas?
