I just purchased a 1962 OMC deluxe. The engine is not being cooled. My owners manual shows a water discharge location around the tilt shaft housing on the right side. My tilt shaft housing area does not appear to have a discharge location and my bolt pattern for the tilt shaft housing is diffrent than the owners manual. <br /><br />Where else might the water discharge port be located?<br /><br />Where is the best place to start to trouble shoot this problem?<br /><br />The water inlet is not clogged and water appears to be ciculating through the lower case. There appears to be some gear lube in the test tank after starting. I just ordered a service manual but I am anxious to start solving this problem
