1962 JW-17 3hp starting issues
RDuplechin
Hi everyone, new member, 1st post. I'm working on my grandfather's JW-17. He passed away in Jan. 1976 so this motor has not been started since the fall of 1975. So far I have: drained and filled the lower gear lube (no water found); changed impeller; dissolved syrupy sludge from fuel tank; disassembled, cleaned (I think) and rebuilt carb; replaced float; replaced plugs. I did not replace or make any adjustments to the points, mags, condensers. I did check for spark and it is there. Admittedly, I don't know how strong that spark should be but it should be enough to start, I would think. I attempted to start and didn't get any life. What I got after 10 or 12 pulls was fuel running out of the carb. I originally thought it was from around the needle valves so I tightened those seats down a little more. Needle valves are set high 1 1/2 & low 1 1/2. It seems the fuel is coming out of the front of the carb between the air intake opening and the manifold going to the air box. There was no spark arrestor on this motor (got one on order) but that is where the fuel is dripping from. I guess that means I flooded it but I don't know why or how to correct it. Thoughts on what to try next?
Part 2 is that when I checked compression I'm getting 51 on the bottom and 62 on the top. I'm guessing (hoping really) that this is either a bad head gasket or stuck rings. I have not pulled the head off yet, I wanted to do a little more diagnosing first. Is there anything I can do through the spark plug hole (PB Blaster or something similar) that might loosen up stuck rings if that is the problem?
When I do pull the head, what should I be looking for that might indicate if I have a cracked block, warped head, cooling issues or something more serious beyond the simple head gasket or gunky rings?
Thanks,
Rick
Honorary Supreme Mariner
Spark should jump a gap of 1/4" with ease and with a " snap " you can hear.-----Just using the plugs is not a good test.-------Any cracks in the coils ?
oldboat1
^^would check ignition first. If you have good spark, flooding may be due to float installation. It's possible to put it in upside down, for example. The initial setting for the h.s. needle (lower needle) might be a little rich -- might start with 1 turn open. Final setting might end up being somewhere around 3/4 open. Mix at 16:1 to 24:1.
Try a little spray lube in the cylinders, turning the flywheel by hand (clockwise). Compression numbers may improve -- would work on spark and see if you can get it running. (Plan to replace coils.) Special motor with a family history -- good stuff.
RDuplechin
Thanks, folks. I actually used a cheapie Harbor Freight spark tester to test the spark. It plugs from the spark plug to the plug wire. The spark is contained in a clear plastic area so nothing was audible. I may open that up to see if I can increase the size of the gap in the tester. I'm not sure about the mags. I have not pulled the flywheel to get a good look. Looking down through the adjustment holes in the flywheel, they look fine. They even look pretty new. ​I'll try resetting the high speed needle. I'll open the bowl on the carb and take a look at the float. Is that float adjustable to maintain less fuel in the bowl?
The good news is that after an hour or so of spraying lube into the cylinders and turning the flywheel I must have done something positive. Both cylinders are reading 62 consistently. Maybe that means that with a cold engine and a compression tester that might read inaccurately I'm ok???
oldboat1
sounds promising. Suggest just setting the float level with the inverted top. I eyeball it.
If pulling it off again, I would hit all openings with carb cleaner again (sounds like fuel in the tank was pretty bad). If the plug on top wasn't opened up earlier, I would do that and clean out the idle passages under there.
lindy46
Float is adjustable by bending the arm. I usually bend the arm VERY SLIGHTLY down (or up when the carb is inverted) from parallel to the carb body to ensure the bowl doesn't overfill. You can clean and adjust the points through the inspection port. Use a strip of business card stock soaked in acetone to clean, then set points gap to .020" when the points are directly under the inspection port. 62 psi and even on both cylinders should be good. You can get an open-air spark tester at any auto parts store for less than $10.
