fiberglassiccollector
Thread starter- Joined
- Aug 16, 2015
- 8
hi this is one of my outboards and i had points put in and i took it out on the upper hudson in the adirondacks it was running slow so i pushed the throttle forward all the way and the motor stopped moving and reved up way to high so i turned it off and then turned it on and tried to shift forward it did the same thing again but then it shifted into neutral too and then shifted into neautral and it worked then i shifted into reverse and it worked im taking it to my mechanic tommorow to fix it but i was just curious if it was something i could do.
