reavesga
Thread starter- Joined
- Feb 14, 2010
- 165
I just purchased a 1962 Johnson 40HP RDS-24M for use on a 1961 boat. The goal is a restored classic. So, before I start taking the motor apart I thought I would check a couple of things. See if we have fire on both cylinders. So I disconnected the wire harness from the junction box so that the motor just has wires hanging out the front of it and removed the plugs. I hooked up a ground so that I could easily see the plug and check for spark. The motor pulls through nice and easy with the plugs out. Lower plug bright blue spark. Upper plug nothing. So I start looking at wiring diagrams and there are vaccum cutout switches, and interrupt switches, etc and they all appear to ground one of the magneto lines. So, the question is with a dead cold motor is spark on the lower plug only normal, or is there a wire I need to hook up some where to get spark on the upper plug. Or disconnect to check for a bad cutout switch and or vacuum switch or do I have a dead coil. Manuals are on the way. So far info on the web not conclusive as I just want to see if I have spark. And what is the purpose of the vacuum and cutout switches anyway. All my experience to date is with Mercruiser sterndrives so this is a new adventure.
The good news, the motor has compression on both cylinders 140psi or so best I can tell. Looks clean.
