If you have the solenoid, you could mount the solenoid in the pan, and use a push-button starter mounted on the lower cowl. You would need a positive and negative battery cable and a short positive (all 4AWG) to run from the solenoid to the starter. Then some 12AWG wire to connect the pushbutton to the solenoid. You could also use another pushbutton to rig up a kill switch.
