1962 Johnson 28HP RX-10 3000 RPM max
bilge22
My RX10 has fresh rings. and seals. and carb rebuilt, and blah, blah, blah. It can not get to full RPMs. I've tried adjustment to the slow and main needles. I also tinkered with the linkage between the carb and timing advance. Slow speed runs great.
Any ideas?
bilge22
Have you checked to verify that's it's running on both cylinders?
bilge22
OK, you were correct! The lower plug is not firing. New coil on order.
Thanks
