GoodMr1967
Thread starter- Joined
- Oct 1, 2016
- 10
Hello. I just got a little 10 hp Evinrude with a 12' aluminum boat for some lake fishing next spring. The seller said it had been 10 years since he had run her, but he figured she should still run. I got her in a barrel of water with some fresh gas (there was 10 year old gas still in the tank:
) and pulled the cord. She started up, a bit rough, but ran for about 5 minutes and quit. There was water flow from the outlet while running. Once the motor quit, I couldn't restart it until all was cool again: more than 1 hour. Out of curiosity, I checked the compression and found a whopping 55 psi in each piston! Looked like a great time to pull the head and see what was inside. You can see the results in the photo below - someone didn't flush
blue
. I am imagining that this project is going to be in depth, but that could be a fun time with my three sons at the workbench with me. Now, for the questions:
1. Are there water passages that I will not be able to clean sufficiently?
2. What is the best method to clean the passages and get to cool running?
3. Is there a chance that new rings could remedy the compression problems?
4. Am I looking at Don Quixote's "Impossible dream" that this motor will run reliably again?
Thanks for any input you can send.
Having trouble uploading photo: basically, water ports are heavily clogged with salt around lower cylinder and ends of pistons are pretty black. I have also disassembled the thermostat and it is shot (as expected).
