1962 Evinrude Lark iv 40 hp junction box question
delt-3
I recently picked up an Evinrude Lark iv 40 hp model #35932. The motor did not come with controls or a junction box. I was able to purchase a selectric control that I believe should work, but I don't have the junction box and corresponding wiring that is needed. Is this something that I can piece together with a solenoid, starter switch, etc. or do I need to find a vintage junction box and wiring.
Any help would be greatly appreciated.
Honorary Supreme Mariner
The last models made did not use a junction box . Voltage regulator and other bits were mounted under the cowling.-----------Finding the wiring diagrams would be your first step.
F_R
Don't forget, you need a voltage regulator.
Racerone made a good point about the under-hood mountings, but other stuff was changed at the same time. For instance the lower front cowling pan.
delt-3
Thanks for the quick replies. I have the wiring diagram, parts manual and the shop manual for the motor. I was able to find the appropriate starter solenoid, but I'm having trouble tracking down the correct voltage regulator. The parts manual calls for #377001, which was replaced with #381538. The problem is I haven't been able to find one anywhere for sale. Does anyone know where I can find one or something else I can use? Any help would be greatly appreciated.
F_R
Let's start off by pointing out that there is no car regulator that will work properly. The correct regulator limits generator output to 10 Amps. No car that I know of has only a 10 Amp system. Charging in excess of 10 A can burn up the armature in your generator.
Moving on, there was a 10 Amp Harley Davidson regulator at one time. It's probably obsolete too.
Moving further on, there is a Solid State 10 Amp regulator to replace the old mechanical ones on Harleys. People say it works on your outboard, but I've never personally tried it. Prowl around on e-bay and you should find it. Again, I repeat 10 Amps. There are look-alike solid state Harley ones that do something like 30 Amps. You do not want that one.
