wildlandff05
Thread starter- Joined
- Jun 15, 2020
- 18
Evening all,
New to the site. Though I’ve been checking out the forums for old Evinrude outboard info.
I bought a 62 Evinrude Fisherman 5.5 at a garage sail a few weeks back. Cleaned the carb, changed the lower shaft oil and it started right up. Impeller shockingly works well. Put it on my 12’ aluminum boat and it ran great for about 20 mins. Suddenly it was running on only one cylinder (top).
Popped the flywheel and both ignition coils looked like they’d been smashed with a hammer. Points looked to be fine so I ordered the coils. Installed a nada. Still no spark. Bought an oem tune up kit and installed new points and condensers.
Put the flywheel back on and spun it by hand. Spark on both! I mounted the outboard up by a garbage can and it started on the first pull. Problem is it was only running on one cylinder again. Flywheel off and nothing obvious. Pulled the coils - cut the spark plug wire about 1/4” to expose new core - reinstalled.
Now I have spark again. I’m a little nervous to reinstall the flywheel completely as I don’t have a puller and I’ve already made 3 trips into town to rent one from Oreillys.
Am I missing something? I’d have replaced the wire as well but I can’t find any in town. Could it be as simple as that? The only other thing I’ve noticed is the new points seem to ride up the pivot post after a few turns.
