1962 Evinrude 40 HP Lark IV No spark
WH3ATLEY
Hey guys, I recently acquired my first boat that has the motor listed above. I want to try fixing this myself, but not 100% sure what I'm doing.
the problem that is in front of me right now is the fact im not getting a spark, i replaced the spark-plugs but that didn't fix it... I will answer any question I can to the best of my knowledge.
thanks :D
F_R
Honorary Supreme Mariner
If you truly don't have any spark, you need to get to the stuff that creates the spark. In other words, you need to pull the flywheel. You will need a flywheel puller to get it off and a torque wrench to tighten the nut to 100-105 foot pounds when you put it back on after you have fixed whatever is wrong.
lindy46
Is it on a boat and connected to a remote key start? The key has to be on to get spark.
lindy46
Have you tested spark with a spark tester? It should jump at least a 1/4" gap with a snappy blue-white spark.
Remove the flywheel with a 3 bolt puller.---Inspect ignition coils / points.----If this motor sat for many years ( happens all the time ) it will need some work.---simple to do.
