1962 Century Resorter Questions
DavidDupont
Hi, I have a 1962 Century Resorter that I am getting prepped to sell. It has a Chrysler Crusader Hemi in it, It has a very loud hum when I start it that is coming from the drive unit. It does not make the noise in forward or reverse, just in neutral. If I move the shifter almost into one of the gears, the noise goes away. Thoughts? Also, how do I check the oil in the drive? Is it the large threaded plug on the left side on the top of the unit?
Thank you,
Dave Dupont
Ayuh,..... Welcome Aboard,..... What transmission is in it,..??
DavidDupont
Thank you,
Dave Dupont
Hi, I think I figured it out. It is a Chrysler drive BTW. To check the oil, there is a large 1 3/8 hex plug on the left side. top, I removed it and it looks like its low on oil. I will top it up and let everyone know how I made out.
Thank you,
Dave
DavidDupont
Hi, The plug is not used to check the oil, the drive is fed oil from the engine crankcase. I am wondering on the trailer it is not getting enough oil back there?
