1962 9 1/2 johnson runs on choke only
seal2127
We rebuilt the carb and now it will only run on choke the tank and the hose/primer is all new we have good spark at both plugs I did a search and have done about everything sugested any help would be great thanx for your time
kbait
Re: 1962 9 1/2 johnson runs on choke only
If it'll run fast normally, and only with choke when slow, likely the low speed circuit in the carb is blocked.
kenmyfam
Still got a fuel blockage in there somewhere.
1946Zephyr
you might also check the condition of the boot in the lower part of the motor leg. When these fail, it often runs like this.:cool:
tashasdaddy
read carb adjustments, single needle. that is what the knob on the left is for.
ezeke
The small capillaries between the needle and the throat of the carburetor are esily clogged and may need cleaning; you will need to remove the needle to clean.
The setup on the low speed varies between model years in that later models have an insert under the core plug called a filler plug calibration pocket.
There are no 1962 9.5 Johnson motors, what is the model number?
