I have a 1962 V4Al 75 hp Johnson that I've done extensive work on to get it up and running again. I'm down to replacing the water pump/impeller. My problem currently is reinstalling the lower unit. The drive shaft spline need to line up with the motor head and that is where I am running into problems. I have read that if you turn the prop at the same time you raise the lower unit into the motor head it well turn the drive shaft to help align the splines. But on this motor turning the prop does not turn the driveshaft. I'm not sure if it's because its the Electromatic shift or what. Also they new water pump kit came with new O-rings for the drive shaft. It goes on just after the drive shaft splines but it is slightly bigger that the original O-ring. The Johnson dealer said the bigger O-ring was just an improvement from the old one. But I'm wondering if the bigger O-ring is what is preventing the drive shaft from inserting all the way.
Any tips for getting the lower unit reinstalled.
Thanks for any help.
