1962 75 hp running rough and under powered
62 Lady Ester
Thanks to those that helped me with my starter problem! I had it replaced and it fired right up. Unfortunately, when I put 4 adults in the boat I could not get it to plane out. It was idling a little rough, but that is not uncommon with this motor. With two adults it seemed to perform fine. Prior to the starter replacement, 4 adults did not slow this boat down. When I pulled it out, I noticed black oil dripping from various locations on the upper and lower unit. I'm not sure if this is related or if I have two issues. Any ideas?
F_R
Honorary Supreme Mariner
Starter and performance problems almost certainly are a coincidence. I'll bet it isn't running on all 4 cylinders. The fuel going through the non-functioning cylinder(s) is going out the exhaust and picking up particles of carbon, turning it black.
EDIT: Could be a ruptured fuel pump diaphragm. That would dump too much fuel in the cylinder that drives it, making that cylinder not fire and the fuel going out the exhaust as said above.
