newfiez
- Sep 26, 2008
- 324
Hi all,
Having an issue with a '62 75hp not starting. I looked for obvious stuff, only found the carbon button in the distributor almost worn out, so I replaced the distributor cap and no fix. I hooked up an in-line spark tester from the coil to the distrubutor and it flashes. There is no spark from the distributor to the plugs. The plug and coil wires seem like they are in good shape.
Could it possibly be the rotor that's worn?
