1962/63 75 hp Johnson Stopped Cranking
62 Lady Ester
I have a 1962 or 1963 Johnson (some debate as to the exact year) 75 hp on my 1962 Starcraft. It ran all last summer with little issue. When I put it in this year it did not want to start. Seemed like a battery issue. I was able to jump it and it ran fine. I replaced the battery and that seemed to do the trick. It worked all day with no problems. The next morning it acted like the battery was dead again (first tried to turn over, then nothing). I assumed the battery was not charging. I took the new battery back to the store and checked it. It was fully charged and working properly. I have since tried it with a new battery as well and it has the same result. The solenoid clicks, but that is all. I fear that I burnt out the solenoid, but I do not know for sure. Does this sound familiar to anyone? Any ideas?
hardwater fisherman
Check for voltage on the battery side of the solenoid. Then turn the key or push the button for start. And then check for voltage on starter side of the solenoid. Also make sure all wires and connections are clean and tight.
F_R
Honorary Supreme Mariner
Agreed, voltage drop tests are the way to go. If you don't know what that is, best to see if you have a buddy that understands electricity. Guessing and replacing parts is a great way to spend money. Might even get lucky, maybe.
62 Lady Ester
Thank you for the help! I have cleaned all the connections to the solenoid. I will check voltage drop. Should the readings be the same? If not, what should be the reading on the starter side? I assume if the reading is not good then I need a new solenoid?
hardwater fisherman
If your battery is good and fully charged you should have 12 or plus volts on the battery side. And if you have less than 12 on the other side the starter is not likely to work.
62 Lady Ester
I checked the voltage. I got 12.3V on the battery side and the starter side. I also checked at the starter and got 12.3V there too. Does that mean that the solenoid is good and the starter may be my issue?
62 Lady Ester
I tried connecting the jumper cables directly to the starter and nothing. Is there something else I can check or is it time for a new starter?
Will Bark
Either new or carry it to a starter/altenator repair shop for a rebuild. Good luck
Will Bark
Are you located where you can get your starter rebuilt/ Way less money than a new one. Good luck
hardwater fisherman
There might be some for sale on EBAY. Also sometimes just a good cleaning inside will bring it back to life.Or as stated rebuilding is cheaper. I took mine apart and cleaned it last year and it is still working.
