1962 40HP Evinrude Big Twin (Shifting issues)
'62bigtwin
The controls for my big twin will not fully shift into forward or reverse, it gets stuck halfway between both. Any ideas what might be causing this and how to fix?
lindy46
Normal if the motor is not running. The shift lever on the motor may not fully engage forward and/or reverse when the motor is not running. You may have to slightly turn the flywheel to get the gears/clutch dog aligned properly to fully engage F/R.
