1962 40 hp johnson electromatic prop pitch?
gary cooper jr
62 Johnson 40 hp electromatic, I will be running this motor on a16 ft 72 in beam aluminum jon boat, what prop pitch will work best?
RCO
What prop is on it now, and what kind of performance are you getting/expecting?
jimmbo
Your engine has an rpm range of 4000 - 5000 rpm. Any idea what rpms you are currently running, and with what prop? If not, I would recommend an 11 or 12 in as a starting point. And if you don't have a tachometer, get one
F_R
Honorary Supreme Mariner
In the absence of a tachometer, probably a 10 1/2 x 12. Maybe a 10 1/2 x 13 if loads are light. As I remember it, they came with a 14" which was pretty useless.
jimmbo
Some years they came with a 13 1/4, others 13, still others 12, and 14. Gear ratios never changed...
Early 60s 14"
Mid 60s 13 1/4"
Late 60s early 70s 12"
Mid 70s 13"
On our 14 ft Skagit with a 1963 40hp Electramatic we usually ran a 12in. I tried a 13 1/4 I found in a shed, it would barely plane the boat, but the motor was in bad need of a tune up. Next season, after a tune up, I tried it again and it did go a bit faster than the 12, but it was slower on hole shot.
