djnick2000
Thread starter- Joined
- Sep 1, 2006
- 7
Ok, I have a 1962 10 hp johnson. This was my great grandfathers motor origionally so I really want to try and keep it running. Right now it wont start. New plugs, new plug wires, new kill switch, points have been cleaned, coils tested and fine....now on to the problem. Origionaly my dad was working on this for me and said that only one cylinder was firing. But if he pulled the top spark plug off and away about a quarter inch, then they would both fire. Now, for some reason, nothing is firing. He reversed the coil packs, just traded there positions, would this affect anything? Right now I think the biggest problem is that I don't think the points are staying gapped right. I set he gaps, tighten everything down, put the wheel back on and pull the starter rope a couple of times and then I check my points and they are gapped wrong again. Am I missing something? I really wish I could see a picture of how everything is supposed to look on a 10 hp johnson so I can see what might be wrong. I'm at a loss and I cant really afford anything new. Not to mention this motor has some sentimental value to me that a new motor wont have. I know very little about engines so I have a hard time trouble shooting at this point. Do all 4 wires under the fly wheel go to the same screw? technically 8 wires I guess. 4 on each side. I apologise about how vague this is, I just feel overwhelmed by this motor right now. Thanks for your help.
