1961 Viking 5 HP model 5d21V
dockyard
This motor runs great but does not pump water for cooling the engine. I've had it apart and everything seems fine. The impeller is a little stiff. Could ,this be the problem?
cajuncook1
Re: 1961 Viking 5 HP model 5d21V
Here is a link to electronic parts diagram that is very close to your year model motor.
http://www.richardlpaquette.ca/5D20V Parts Manual.PDF
http://www.richardlpaquette.ca/vikingmanuals.htm
Alot of the parts from (Gale) Viking outboard cross match with parts that go to Evinrude and Johnson outboards of those years as well. Gale, Evinrude and Johnson outboards were housed under the parent company umbrella of OMC.
Here is a link to a replacement impeller. (If you can try and stick with the OMC/BPR) replacements because the impellers are correctly sized and not as stiff.
http://www.marineengine.com/newparts/part_search.php?part_num=277181&x=18&y=7
Check to make sure there is a impeller key so it may turn the impeller, sometimes it is forgotten and the impeller will surely not pump water. Also, when you are bolting the lower unit back up, watch very closely that water tube is lining up with the water pumping housing grommet. If not careful it can not slide in or be displaced when putting the lower unit back on.
Good luck
