coolguy147
- Jul 14, 2008
- 2,817
heres an update of the motor ive been preparing for and reaseraching and checking over.
so far i know it was last run in about 1990's.
check compression all cylinders between 128-135. top piston highest 135 and bottom piston was about 127-128. so good heres its like 140 new and again hasnt ran so rings probably stuck a bit
check spark today got no spark i made sure i turned the key had spark plugs all plugged in once then made sure they tocuhed the block no spark on any cylinder.
checked prop today looked good really heavy bronze no fishing line. then i greased it up nice and good. installed prop then put nut back on then pulled out two of the tabs on the washer
then i wd-40ed every nut and bolt on the outside of the motor. exhuast housing lower unit screws and bolts holding it on and such since they were rusted im most likely going to replace them.
next step is change gear oil inspect it etc. take lower unit off and replace impeller. i hear u need a special tool to take the water pump housing off where can i get this tool?
after is ignition. did some looking around ( first time working on a distributor) so i know one coil one cond. and one point. in there. im getting the instructions to disassble the cap from a friend. i have a red cap by the way. and the model number is like ad-3 or something like that cant remember
any thoughts advice bad things.
i know the cap and rotor can be really expensive but i might take the chance. so far i spent nothing on the motor so far
