1961 johnson 40hp outboard
bernardjeddry
i would like some info on my motor please.. i have cleaned the carb,changed the gassand made sure there is sparke, and checked to see if there is gas going from the pump to the carbbut the motor still wont run we took it one day and it would go than boug out when we brought it home we took it apart now it spits and sputtersbut wont stay goin it is almost like it floods it self i put gas the carb and it will start for a few seconds but thats it .. where should i have the leen rich setting set to?if you can give me any help i would appreciate it thxs
Joe Reeves
Re: 1961 johnson 40hp outboard
Depending on which carburetor might be on that engine (1 needle valve or 2 needle valves)...........
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
bernardjeddry
heythanks!!! so you think that those leen and rich knobs will stop the motor from running? there is only one carb is there any timing on that motor cause it seems like it is off!! i dunno.well thanks again!i would love to get it workin but if i cant very soon i guess we will be sporting a new 90hp O ya!!!! thxs
F_R
Honorary Supreme Mariner
You probably need to get the flywheel off and see what is wrong in there. Could be cracked coils. Could just be dirty points. Could be the flywheel key is sheared because the last guy didn't know what he was doing. The carb knobs might keep it from running if they are WAY off.
bernardjeddry
hi! thanks 4 the info .. do i need a special tool to get the ffly wheele off or can u let me know how? thanks so much you guys are great!!! now that i ajusted the leen and rich it starts 4 afew seconds but back fires and stip and sputters let me know what you think ,....thank again!!!is there any type of timeing or some thing like that that would make that happen? it seem like it floods itself or something... any thing you can tell me to try would be awsume...the motor is a 1961viking40 hp thxs
