1961 Johnson 10hp - QD-22 - Fuel Pump Issue?
ScottyOMC
Hello,
This is my first time working on an outboard so my apologies if I’m missing something.
I just bought a 1961 Johnson 10hp QD-22 motor. Guy said it hadn’t run for a couple years. I took apart and cleaned the carb, checked the coils, checked the compression (about 80-90 on top cylinder, can’t get my gauge on the bottom on because of the size of the gauge) put in new sparks, and got the motor running and ran a few litres of gas with sea foam through it.
Only issue is the motor will only run when the gas tank is elevated. I put the gas tank on top of garbage cans so it’s above the motor and then it runs fine. When I put the tank on the ground, it runs for 30 seconds and then dies.
Is this definitely the fuel pump? Anything else I should be testing or looking at. Any suggestions for testing the fuel pump?
Thank you very much!
oldboat1
Fuel pump diaphragm. They get dry/stiff and take on a set -- new ones are flexible. Replacement pump is the small square one 0388685, I believe. Big believer in oem parts, but the cheap foreign pumps on the market seem to work fine at maybe 1/4 price or less.
Crosbyman
ground to pump.. 2-3 feet . may be a bit high
have you tried a normal 12 inches or so... if ok pump is good ..for now
oldboat1
^^point is good. Get a fresh pump for backup.
Btw, water in your test tank should be comfortably above the water pump.
ScottyOMC
Thank you all for the feedback!
Got the problem fixed! The note about the diaphragm got me thinking more about the fuel pump. When I first got the motor earlier in the week I opened the fuel pump to clean it up and I must have put a spring back in the wrong spot.
