1961 evinrude fastwin 18hp model 15034
GAZOO
I have recently aquired a 1961 evinrude model # 15034 18hp fastwine, i have rebuilt the carb, taken apart the engine and re-assembled it, everything is looking good and i'm rearing to give it a try.
However i drained the gear case oil and now i'm wondering wich gear oil to use.
I've seen 70w90, 80w90, sae90 on the net, any idea???
I've picked up a bottle of sae90 semi synthetic.
Any recomendations would be greatly appreciated.
Thank you!
GAZOO
Re: 1961 evinrude fastwin 18hp model 15034
Also wondering about wich plugs to use, it had j8c plugs in it when i took it home so i bought new champion j8c, however i've heard that i would be better off with j6c.
Any idea's on this would be great.
Thanks again.
1946Zephyr
Go to the marine supplier in your neighborhood and ask for the High Viscosity Gear Case Lube, more manual shift models. Also make sure you get two new washers for the drain plugs too.
How does your old oil look? Is it milky white, or black?
J8C's will be fine. J6C's are ideal, but the 8's will work just fine. As long as the piston doesn't slam the gap closed. :D
GAZOO
the oil was pretty black, no shavings or water came out though.
hopefully next weekend i'll put the motor in a barrel and give it a try.
if everything is good i'll get some j6c plugs and use the j8c's for spare. and change the oil a few times just to make sure everything is clean.
kfa4303
Banned
80w90 oil is fine. Good sign that the oils is still black. However, if it sould become milky after you've been in the water, then you have a water leak in your lower unit. If you're up for it, you can change the Lower Unit seals, however lots of folks resign themselves to having a bit of leaking in these older motors and just change the oil a few times each season. Keep us posted.
