So a couple of days ago i picked up a 1961 Evinrude Fastwin 18 hp outboard. I saw the thing running in the barrel, it started on its first pull, all looked good, water pump etc. So when i was at the lake i found out the shear pin was broken, fixed that, then a spark plug blew when i gave it full throttle. Repaired the threads, cleaned the carb, pistons were all good, replaced the fuel lines (they were cracking) adjusted the points to 0.020 (both spark plugs are firing bright blue) and made sure the gap was set. The issue is now the thing wont start. I have no idea what is going on with it. i tried everything, but it doesn't want to start. I adjusted the high low speed trims and all, looked on all these forums.
One thing i did notice is that the engine it pretty hard to crank now. When i remove the spark plugs its easy to crank, when i put them in, it become really hard, is this an issue? could this be another effect of something that may not be causing it to start?
Oh and i did my compression test, both cylinders have great compression.
PLEASE, I NEED HELP FAST, this week im planning on going fishing with my father whose not going to live much longer, and i need my boat outboard working!
Thanks of any help!!!
