Hello everyone, I fired up my evinrude 18hp 1961 outboard in a garbage can with water a few days ago. It ran fine. Then it sat in my garage for a day with no problem, I didn't do anything to it, then I started noticing a gasoline smell all throughout my house today. I opened the garage to find a giant puddle of gasoline/oil on the floor underneath my outboard. I took the cover off and noticed a giant puddle of blue oil in the top casing of the outboard. It was also dripping out of every small hole and bolt on the lower part of the motor. I disconnected the fuel line to find fuel shooting out of the gas tank valve/fitting. I'm wondering what the heck is happening. My motor was in the garage hadn't been turned on and all of the sudden it started leaking like crazy while turned off. I am wondering if the fuel line or the gas tank was the problem, is it normal to be sending fuel to the motor when not turned on? Or is it a problem with something inside the motor? I know 2-strokes leak but i'm pretty sure they don't leak this much? What are your thoughts? Is this a simple fix? I'll try and get some pics up
