1961 evinrude 18hp leaking from everywhere like crazy while not even running HELP
Qjensen31
Hello everyone, I fired up my evinrude 18hp 1961 outboard in a garbage can with water a few days ago. It ran fine. Then it sat in my garage for a day with no problem, I didn't do anything to it, then I started noticing a gasoline smell all throughout my house today. I opened the garage to find a giant puddle of gasoline/oil on the floor underneath my outboard. I took the cover off and noticed a giant puddle of blue oil in the top casing of the outboard. It was also dripping out of every small hole and bolt on the lower part of the motor. I disconnected the fuel line to find fuel shooting out of the gas tank valve/fitting. I'm wondering what the heck is happening. My motor was in the garage hadn't been turned on and all of the sudden it started leaking like crazy while turned off. I am wondering if the fuel line or the gas tank was the problem, is it normal to be sending fuel to the motor when not turned on? Or is it a problem with something inside the motor? I know 2-strokes leak but i'm pretty sure they don't leak this much? What are your thoughts? Is this a simple fix? I'll try and get some pics up
F_R
Honorary Supreme Mariner
Simple fix: Unplug the fuel hose when not in use. Especially when stored inside. Wouldn't be a bad idea to loosen the gas cap to relieve the pressure also. Opinions vary as to whether or not to then leave it loose. Best solution is store the tank outside. Got a shed?
lindy46
Don't know where you live, but if you're experiencing the extreme heat we're having in Tennessee, fuel expansion can cause all kinds of problems. I always store my gas tanks in an outside shed.
