1960 Johnson seahorse 3 hp
Speedcat
Recently purchased a 3 hp seahorse and lower unit will not tilt up. Any ideas or suggestions from past experience.
Thanks
Speedcat
F_R
Honorary Supreme Mariner
Is it steered around to forward position?
F_R
Item #26 nut on #29 bolt is the tilt friction adjustment. Loosen or tighten as desired
Item # 53 is the hold-down latch. It should automatically latch or release, according to which direction the steering is pointing.tilt friction.jpg
Speedcat
Thanks, will try and give that a try this evening and let you know.
Speedcat
Speedcat
Item # 53 is the hold-down latch. It should automatically latch or release, according to which direction the steering is pointing.View attachment 346895
Just loosened it a little and it's good.
Doesn't it have a coter key so if you hit a stump it will break like the 2 hp seahorse or is that what 29 & 29 does?
Thank You!
Speedcat
