1960 Johnson QD-21 10hp...need some help..
drew10159
I own a 1960 Johnson QD-21 10hp... The motor discharges an green oily substance in the water intake. I am looking for advice ..where can I get a manual? And, how do you change the oil?
bubbakat
Re: 1960 Johnson QD-21 10hp...need some help..
scroll the page down and look in the left hand corner and you will find a link to get your manual. there should be two screws at the bottom of the lower end of mtr and one is for checking and one is for draining. be sure to refill from the bottom to keep trapped air out.
drew10159
To change the oil, I need to take out both screws and let the oil drain.. Is it oil or grease I replace it with? How do you fill it from the bottom?<br />Thanks.
bubbakat
DREW if it is not a electric shift it will use I think sae 90 hypoid you can get this at any marine store if you don't have one close try wal-mart that is where I get mine and the pump to.<br /> You insert the hose in the bottom and pump till it comes out the top. As for the oil you see on the prop it might be unburned fuel coming out the exhaust port. I would chang my lower unit oil and if it wasn't milky looking the seals should be ok.<br />If it is a little milky looking and the mtr has been sitting could be condensation.
Solittle
Also it is a must to replace the nylon O rings for the screws.
