1960 Johnson 75HP Super Sea-Horse
Duovirginia
I am restoring a boat with this motor. I need a few parts. For instance, the wiring harness (starting harness that plugs into the motor and goes to the starter box in the boat). Is harness available anywhere? It's bad and I by-passing it right now. But I am not getting power to the spark plugs. What is the motor shut controlled by so I can bypass it also. Is it the wire that attaches to the magneto?
But my main question is, where is the best source for parts?
jimmbo
Welcome to iboats
Here is a link to a Service Manual. It does have a couple of Typos.
75hp @4500rpm not 4000
Electrical Manual
There used to be links to sites that did sell Wiring Harnesses for old motors, but it seems they have evaporated
Parts: iboats sell parts https://ww2.iboats.com/Boat-Motor-Parts/dm/view_id.268656
There are others but since iboats sponsors this site, they can't be named
Honorary Supreme Mariner
The magneto makes it own spark.----And 12 volts is not needed from a battery to run this engine.
jimmbo
A 1960 would be, as racer said, Magneto. In 1961, both Magneto and Battery Ignition were offered, depending on the Model
