1960 Johnson 75HP super sea horse
holiemackerel
Hi all. Our family recently bought a 1960 Arkansas traveler with a 1960 Johnson 75HP super seahorse. the current set up is bypassing the voltage regulator and ignition. (hot wired). my questions are a) can i run this motor the way it's set up and/or b) does anyone have the wiring harness from the side of the motor to the voltage regulator? thanks in advance.
Chris1956
Honorary Supreme Mariner
Any idea if that motor has magneto ignition or battery/coil ignition? Do the spark plug wires exit the bottom of the distributor cap or on the side?
Do you have the belt-driven generator, mounted opposite of the starter?
