I have 2 more questions on this motor. The first is today I noticed that there was a screw missing on one side of the lower unit (starboard), and it looks like the other one on the same side has been replaced before. The 2 on the port side are both there fine. Does anyone know what these screws hold and can I just get a replacement screw and install it with the motor as is, or does it hold something internal that I'll need to remove the lower unit for? If so does anyone know what size the screws are?
2nd question, when I bought the boat I noticed that the trim bar is installed in 2 different notches on each side (see picture). It seems this was done to prevent the motor from locking into position since the linkage is missing between the trim lock and the lever on the transom. Am I right in assuming that this bar should be in the same notch on both sides to lock it into the down position? I have it the motor swing up a few times while in reverse. I also have a new linkage on order to regain functionality of the lock lever near the transom.
