1960' ish 40hp johnson outboard
Wattmann33
was out last night in my boat and on the way back to the dock i was running about 3/4 throttle when the bow dropped. thought i sheared the pin but on futher inspection today found that the rubber bushing in the prop went bad. have been looking around today online but haven't seen a prop like the one i have (2 blade) can't finde any #'s on it to know what pitch it is. and what i have seen online all of them have been 3blade. any suggestions????
Willyclay
Re: 1960' ish 40hp johnson outboard
Have a prop shop re-hub the two-blade prop. If you wind up buying a "used" three-blade prop, expect it to have a spun hub also. Good luck!
