Solomon_Man
Thread starter- Joined
- Sep 16, 2009
- 110
All,
Last few weeks been picking up a few project outbords (1950's) and ran into a 1960 Evinrude Fisherman (5.5HP).
My 10 yr old son took a interest to it but it was missing a few parts. So being something I would like him to tackle....we were able to pick up the missing parts very reasonable from a few fellas my son and I have met in our outboard projects.
Anyways we usually replace all the under the hood "soft\common wear out parts" on a outboard but we have never worked on a 1960 or newer outboard. We are more of a 1950's Johny Rude collector\tinkerer.
So on the 1960 I was thinking on replacing the following;
ignition points
ignition coils
wires
plugs
wire caps (plug to wire)
carb kit
lower unit seal kit
impellor
thermostat
fuel pump\fuel pump kit
The point of this post is all the above parts are easily obtainable but I noticed that the fuel pump/kit seems to be only available in a new fuel pump form not a replaceable diaphram/spring/seal kit as I hoped/expected.
Is it possible to get a rebuild kit for the current fuel pump? Please advise on where to purchase, if available.
If I end up buying a new pump will the new one be able to be rebuilt?
Our plans are to run this on a little Jon boat my son and I have had our eye on from a friend.
Thanks,
Chris
ignition points
ignition coils
wires
plugs
carb kit
lower unit seal kit
impellor
thermostat
Thanks,
Chris
