1960 Evinrude Sportwin 10hp Not Running
dtketcherside
I am trying to get this Evinrude motor running but have yet to figure out the High Speed/Low Speed adjustments knobs. The motor will start up with the choke out, but when I try to adjust the slow speed knob, it just sputters out and dies. Also, the SS knob only has a movement from 3 to 5. It will not go any farther below 3. Does anybody have any ideas on what I could do to get it to run?
oldboat1
If the motor is new to you, should replace the impeller first. Likely need to rebuild carbs, but not necessarily to get it running. Take the knobs off (think the '60 has the set screw in the middle -- loosen it and pull off the knob). Gently close both needles clockwise until seated. Back out the l.s. needle about 1 1/2 turns, and the h.s. needle 3/4 to 1. That should allow you to start it, then adjust settings.
