Re: 1960 Evinrude Lark 2 wont stay running
Glad you got your bits installed. For starters, make sure that the head bolts are torqued to the proper spec. Next, makes sure the spark plugs are properly installed and that the lead going from the coil located above the carb is connected to the top (#1) sparkplug with the other lead connected to the lower plug. You can connect the starter leads to the battery to test the system. The motor should have a black, push button kill switch on the front, if memory serves. Do you have a pic? You'll also want to use 24:1 fuel-oil mix. Spraying a bit into the cylinders before you install the spark plugs can help prime the system a bit. You also need to run the motor in a test tank with water filled up to about 1"-2" below the main exhaust port. Don't be surprised if it takes a few frustrating attempts to get her to fire up, but if it doesn't start after 5-6 tries, I would take a step back and start troubleshooting. Good luck. Keep us posted.
