1960 evinrude 40 hp with no top speed
Dickinson
I have a 1960 40hp evinrude that has not top speed at all. I pin the throttle and it goes a bit faster than an idle but not really more than 1/4 speed for a 40 hp. I have good spark on both cylinders as well as fuel coming though the pump. Carb has been cleand and throttle is pinned inside the carb as well. Any thoughts? Please? Please?
Boss Hawg
Re: 1960 evinrude 40 hp with no top speed
Read the TOP SECRET files at top of page :cool:
You most likely need to
check compression
rebuild carbs
link 'n synk
find/fix air/fuel leaks
check spark
ect ect ect
:rolleyes:
tashasdaddy
carb adjustments also.
Boss Hawg
And the list goes on & on & on :eek: :p
tashasdaddy
as you said 90% of it is covered in TOP SECRET.
MushCreek
My guess would be a bad coil. Although they both may spark, they break down under load, and you're basically running on one cylinder. Older OMC's were known for coils going bad with age.
F_R
Honorary Supreme Mariner
Agreed. As in Ho-Hum, here we go again. Another guy trying to fix a lack of power problem by cleaning the carburetor. Instead of me typing it all out agian, just read this thread:
http://forums.iboats.com/showthread.php?t=329196
