1960 75 johnson water in #4 cyl
tcan
I have never had one of these engines apart would really like some pointers/tips. Run for aprox 2min lost about 1/4cup fuel in water. No leaks in fuel lines or carbs. pull spark plugs #4cyl water droplets on plug. My first guess is the head/gaskets But I would like to know if the intake or crankcase is water cooled aswell. Is there another way for water to get into it.
iwombat
Re: 1960 75 johnson water in #4 cyl
It's possible for water to come in through the exhaust gasket too. If you find that #4 is low that indicates a head gasket.
tcan
Thank you. I will check overall compression and check the exhaust seal as well.. It could use a good tuneup anyway. Thanks again
Chinewalker
Most likely a blown head gasket - not uncommon and that's what I would check first...
- Scott
tcan
fixed the head gasket! problem solved.Thanks guys.
