1960 5.5
willjb
Does anyone know if this motor has a tell-tail hole,or does it go out the exhaust?
Joe Reeves
Re: 1960 5.5
Will.... That model has no water outlet tell-tale. The water exits via the exhaust area outlet.
Chinewalker
Re: 1960 5.5
Water will exit two areas - the exhaust relief mid-way up the back of the motor leg, and it'll also exit with the main exhaust under the cavitation plate... The hole in the back of the leg is what you check to see if you're pumping water. Should be a good gush like a garden faucet on low.<br />- Scott
