Re: 1960 40hp Evenrude Lark II Lower Unit
If it's electromatic, then only OMC type C, or Premium Blend Gear Case Lube will work.<br />If it's not, which is to say you have a shift handle on the side of the engine, then any 90W oil specified for outboard L/U's will work fine, like the stuff you find in Walmart.
