1960 18hp rude throttle linkage broken
tbfosback
Hi guys I have a 1960 18hp model number 15032 rude. The plastic piece in the throttle linkage that goes on the timing advance is broken. The little piece is just above the 90 degree gearset. Where on earth do I get one of these?
freddyray21
Re: 1960 18hp rude throttle linkage broken
I think I know what you are talking about. I might have an extra laying around.
kjdunne
Are you describing the plasitc socket that snaps over a metal ball and the other end threads onto a linkage rod? They are available thru Evinrude dealers. Many carry them in stock.
F_R
Honorary Supreme Mariner
Part number 304155, available from any Evinrude dealer. It's the round pin with flat key ends, right?
tbfosback
It is the piece that goes onto the end of the linkage shaft. It does have a keyway on it. The keyway is broken off.
